Fuel injector upgrade
Old Apr 20, 2015 | 06:45 PM
jcm9846's Avatar
Default Fuel injector upgrade
Have a 94 Accord with a H22A motor swap. Found some injectors that I was going to upgrade to but they say you must remove the OEM resistor. Do you just unplug it from the vehicle to run the injectors ??
Old Apr 21, 2015 | 08:25 AM
No, you must substitute a direct power supply path from voltage supply to the injector resistors to voltage delivery leads (4). See wiring diagram in shop manual. If you unplug the resistor bank, engine will not start (no injector voltage).
thunder_x
Sep 9, 2006 05:18 PM
bobs87
Feb 14, 2006 05:48 PM
FlyLow
Dec 4, 2005 10:45 PM
dinzer
Aug 9, 2005 11:17 AM
Mar 1, 2005 09:39 PM
