ClemsonSoftball |
06-10-2020 06:47 AM |
Fuel Relay Switch?
I have a 2007 Honda Accord 3.0, 6 cylinder. I started the car and the engine mount broke making the engine vibrate lke a bull in a rodeo. The engine cut it;s off with the key still turned on. I replaced the engine mount but then it would not even attempt to start, no crank. When I turned the ignition I could hear one click, I checked the starter and a connection had come loose because of the violent shaking. The engine now cranks but will not start, I thought I would check to see if fuel was getting to the engine. I sprayed starter fluid but it did not help. Is there a main fuel relay switch that I can check to see if was shut down because the car computer thought it was in a crash? Where would it be located, I cant find anything on the interent for a location of it. How can I check a simple way to check if the spark plugs are working. Any thoughts would be appreciated. I need help big time. I need my car to get to work. Please help me.
