Fuel Tank Vapor Control Valve?
Old Oct 22, 2008 | 11:33 AM
480Ruger's Avatar
Default Fuel Tank Vapor Control Valve?
The MIL came on after I filled the car up two nights ago. No codes and the scan tool says the light should be off. I have the 98-02 Service Manual V6 Supplement but not the Service Manual.
How do I check the Fuel Tank Vapor Control Valve? Any other things that cause this problem while/from fueling?
Thanks Gregg
Old Oct 22, 2008 | 11:35 AM
finch13's Avatar
Default RE: Fuel Tank Vapor Control Valve?
Not screwing on the gas cap at least 3 clicks will trigger the CEL and tell you to check the evap can and what not.
If the light is still on scan it again and clear the code... or try a different tool.
Old Oct 22, 2008 | 01:43 PM
480Ruger's Avatar
I did not know that would cause a code but I actually tried that just to see and even disconnected the battery for thirty minutes just to see if it would clear the light. Still no codes to clear and I did use a friend’s scan tool along with mine. I’m not sure if I’m even on the right track. I just know what I was doing when it started which was just fillingup.
If I did want to check the Valve what do I need to do and is it on top of the tank where the fuel pump housing is?
Old Oct 22, 2008 | 01:53 PM
finch13's Avatar
001 FILTER SET, FUEL
003 PUMP SET, FUEL
005 VALVE, ONE-WAY
007 FILTER SET, FUEL PUMP
011 VALVE, VENT SHUT (O.R.V.R.)
016 METER ASSY., FUEL
028 TUBE, VENT
honda98accord
Apr 18, 2013 05:58 PM
ReadyToRetire
Jan 15, 2012 11:59 AM
mtill58513
Apr 13, 2011 07:00 PM
corlude
Apr 3, 2010 09:20 PM
Gliderpilot
Jul 2, 2009 11:10 AM
