Fuse Box Diagram for '94 Accord
There should be a fuse diagram on or inside all of the covers for the fuse boxes.
I bet here antenna is grinding? If you can't locate the fuse, just unplug the antenna motor. It's easy to access, you just need to pull out the trim piece covering it in the trunk.
ORIGINAL: finch13
ORIGINAL: maineduckhunter
its not on the one under the hood, but I haven't found the box in the car yet
ORIGINAL: finch13
That's odd... it should be printed in white on the cover... or at least molded on to it...
I found the fuse box inside the car, but she lost the cover to that too....so no diagram.....so just took some advice and unplugged the motor to the antenna in the trunk....NO MORE GRINDING!!! Thanks for all your help!!!
