Fuse help please.
Old Jan 9, 2011 | 09:41 AM
bootyleggs's Avatar
Default Fuse help please.
Hello. I have a 05 accord that I needed jumped. The interior of the car still had a little power. I had AAA come out to jump the car which didn't work. I replaced the battery but now the car has no power at all. I'm thinking it is a fuse. Does anyone know which fuse I should try to replace to resolve this issue?
Sorry for being a car idiot but I have no idea what I'm doing here. Any help would be great! TIA!
Old Jan 9, 2011 | 11:20 AM
It may be the main battery fuse, located in the under-hood fuse/relay box, for your car it is either an 80A or 100A fuse. To remove it and replace it requires a philips-head screwdriver. It is held in with two screws. Disconnect negative battery cable first before you attempt to replace it, so you don't get shocked, etc. You can get this fuse at almost any auto parts store.
I will post the image in a short while.
Old Jan 9, 2011 | 11:23 AM
bootyleggs's Avatar
@Redbull-1
Thank you very much! A picture would be a huge help. Thanks again!
Old Jan 9, 2011 | 11:26 AM
This is from the owner's manual. Although this image shows it as a 100A fuse, check to see whether yours is an 80A or 100A and only replace it with the same amperage.
Attached Thumbnails Fuse help please.-fuse-box.jpg   Fuse help please.-fuse-box2.jpg   Fuse help please.-large-fuse.jpg
Old Jan 9, 2011 | 11:33 AM
bootyleggs's Avatar
@Redbull-1
Thanks so much! I'll check it out now and let you know how it goes. I really appreciate your help my friend.
Old Jan 9, 2011 | 11:39 AM
No problem. The AAA guy might of did something by accident, such as hooking the cables the wrong way and blew the fuse. Let me know how it goes.
Old Jan 9, 2011 | 02:28 PM
bootyleggs's Avatar
Well, I went to 4 stores and no one had the part. I'll check the web or a honda dealer tomorrow and report back. Thanks again for your help!
Old Jan 9, 2011 | 03:55 PM
Is the fuse is blown?
If so, you can pick one up at a junkyard. Like redbull said, make sure it is the same amperage.
Old Jan 10, 2011 | 08:50 AM
bootyleggs's Avatar
Yes the fuse is blown. I'll check junkyards too. Thanks for your help! We are snowed in today in Atlanta so I'll try tomorrow.
Old Jan 13, 2011 | 04:55 PM
bootyleggs's Avatar
Problem fixed! It was the fuse. I was able to get the part today. I want to thank everyone for the help. Redbull-1, if you are ever in Atlanta, beers are on me. Thank you very much for your help!
