Gas tank
Old Mar 23, 2007 | 06:05 PM
play4801's Avatar
Default Gas tank
Hello I have a problem with my gastank, I posted a problem about my transmission and the help I got here was very helpful, so thank you. Well the problem I am having is that theres a little line in the middle of the tube that puts the gas in the tank when filling it up. I dont know what thats for and I am having trouble hooking it back up. I am thinking its for air but iam not sure.
Old Mar 23, 2007 | 06:26 PM
sir_nasty's Avatar
Default RE: Gas tank
if I am thinking of the right tube it's either a vent tube or it's a return tube for fuel shutoff etc..... how'd it come disconnected and when did you notice it? and if you posted your vehicle info in your signature and I missed it I appologize but what kind of car is it?
Old Mar 23, 2007 | 06:29 PM
play4801's Avatar
Its an 1990 Accord EX, it came off when I took the gastank off to fix a leak. I dont know if its that important to hook back up, butI want to make sure before I do somthing stupid.
Old Mar 23, 2007 | 06:57 PM
sir_nasty's Avatar
If it's connected to the gas tank I would re-connect it.... I believe that is the tube that fuel bubbles up through when the gas tank is full to cut off the nozzle....
Old Mar 23, 2007 | 07:05 PM
play4801's Avatar
so does it connect somewhere inside the line on the other side(not the gas tank side)
Old Mar 23, 2007 | 07:10 PM
sir_nasty's Avatar
Here is a fuel tank guide for a 89 I think it will be similar....
[IMG]local://upfiles/3079/FB08F1E4F9FB4E399B4E81200F8F4A6E.jpg[/IMG]
Old Mar 23, 2007 | 07:14 PM
play4801's Avatar
Thanks for the help once more. That picture will help me out alot.
Old Mar 23, 2007 | 07:16 PM
sir_nasty's Avatar
no problem, let us know if you run into any snags....
Old Mar 24, 2007 | 01:01 AM
cheggie's Avatar
I just replaced the tank in my 91, and I noticed the short tube coming from the tank. I assumed it must connect to a line in the filler tube, but I found no corresponding line in the filler tube on the vehicle. I looked and felt in there, and found nothing. I did not connect it to anything during reassembly.
Old Mar 24, 2007 | 11:22 AM
There should be a fitting a top of filler tube to connect the rubber hose. If you remove your gas cap you can see the air return entry point. The ventline allows air trapped in the tank by rising fuel level to vent. If the vent is not open, filling the tank will be very slow. If you left the open end underneath the car it would be prone to dirt and water entering the tank, and the emissions system could not work as designed.
bjr001
Nov 25, 2010 12:05 AM
play4801
Dec 11, 2006 01:31 AM
shastylz
Dec 9, 2006 05:20 PM
iridebmx33
Nov 21, 2006 08:51 PM
compassltd
Jun 9, 2006 12:03 AM
