Gear Oil
Old Nov 14, 2019 | 10:03 AM
Nyarayne0103's Avatar
Default Gear Oil
Having trouble shifting gears I my 2001 honda accord manual transmission, do I need tranny fluid, gear oil or both? Where do I put the gear oil if needed?
Old Nov 14, 2019 | 10:14 AM
rockhoundrob's Avatar
look at this video...
If this is not the same year, then do a search on youtube...
Old Nov 14, 2019 | 02:15 PM
UhOh's Avatar
Tranny fluid needs to be replaced every so often ^^^, but difficulty shifting can also be a dragging clutch.
When you put it in reverse, does it grind? - if so I'd look to clutch after you replace fluid.
Nyarayne0103
Nov 14, 2019 09:12 PM
kinghonda
May 24, 2011 08:22 PM
ughcord
Mar 12, 2010 09:09 PM
Mpwr
Aug 11, 2006 12:24 AM
