General Conversion question
Old Oct 1, 2007 | 12:08 AM
Shikaro's Avatar
Default General Conversion question
I was reading and Import Tuner Mag (I think) and read about converting an automatic transmission to a manuel transmission. Is this possible, and how would I find out how? Thanks in advance.
Old Oct 1, 2007 | 05:40 AM
Default RE: General Conversion question
it is deffinatly possible, just very expensive, and probably not worth it, as it is probably cheaper to sell your car and buy one with a manual transmission
Old Oct 1, 2007 | 09:25 AM
00AccordLX5spd's Avatar
Registered User
You don't really modify the transmission either. You drop out the automatic one and install a manual trans from a donor car. As said above, likely more expensive than the car is worth. Unless you can do everything yourself and all you are paying for is parts. Use the "search" function on this site. Also check the DIY section.
Plunker
Jan 6, 2011 12:51 PM
MARcelyCEL
May 11, 2010 06:52 AM
MOHORO25
Apr 1, 2009 07:00 PM
91boz
Feb 6, 2007 12:52 AM
tibbo
Aug 31, 2006 01:59 AM
