General CEL question.
Old Apr 22, 2010 | 07:56 PM
MARcelyCEL's Avatar
Default General CEL question.
I was just wondering if a bad VSS (speed sensor) will cause the CEL to go on. Also, what ways are there to check if the VSS is indeed bad?
Old Apr 22, 2010 | 08:27 PM
g22cd5's Avatar
Supper Moderator
Yes it can pop a CEL. But check your codes 1st be4 you assume that it’s VSS
Old Apr 22, 2010 | 08:55 PM
MARcelyCEL's Avatar
thanks g22... i'll be sure to see what code(s) it's spittin out...
Old Apr 22, 2010 | 09:45 PM
g22cd5's Avatar
Supper Moderator
Get back with us on the codes and we will do the best to help you out.
Old Apr 23, 2010 | 11:42 AM
One way for the VSS.... if the VSS is bad then the cruise-control won't work.
So for example... if you get an error code for VSS yet the cruise-control works, then you know the sensor is OK so you need to find wiring problems in the car.
Old May 10, 2010 | 08:05 PM
MARcelyCEL's Avatar
thanks HAF... replaced VSS, speedometer works... now to figure out why my cruise control doesn't work... and troubleshoot my weird idle
Old May 11, 2010 | 06:52 AM
This really belongs in General Tech, so I'll move it.
Plunker
Jan 6, 2011 12:51 PM
MOHORO25
Apr 1, 2009 07:00 PM
Shikaro
Oct 1, 2007 09:25 AM
91boz
Feb 6, 2007 12:52 AM
tibbo
Aug 31, 2006 01:59 AM
