Glovebox Light On
Old Jan 17, 2008 | 03:53 PM
jackkpts's Avatar
Default Glovebox Light On
The light inside the glovebox on my 2006 Accord EX sedan is on whenever my lights are on. Is this normal? Thanks...Jack
[align=left] [/align]
Old Jan 17, 2008 | 04:19 PM
falkore24's Avatar
Default RE: Glovebox Light On
only when the glovebox is open ..... see if it goes off when you push the button. Since it is a simple contact switch, if the light stays on, there is a short supplying it with power.
Old Jan 17, 2008 | 06:15 PM
The light shouldn't be on, unless the glove box is open. Just push the button like Falkore said.
Mine was lit up all of the time, and I found that the bolts in the latch mechanism had loosened up. I just tightened them down and the light is on only when the box is open.
Old Jan 17, 2008 | 06:36 PM
HondatechAV6's Avatar
actually, the 06 accord isn't switch operated. it's designed to come on whenever the headlights are on. there is no problem, it is normal.
Old Jan 18, 2008 | 08:35 AM
falkore24's Avatar
hmmm ..... seems like a bad design to me. Do the bulbs die often then?
Old Jan 19, 2008 | 07:20 PM
not that i know of. i've never seen or done one! [8D]
96Red240sx
Jan 12, 2007 09:12 PM
novegi
Dec 25, 2006 06:43 AM
rockchalkseahawk
Oct 4, 2006 01:10 PM
rodneyzeng
Jan 21, 2006 06:47 PM
