Good way to get the engine mount back on?
Old Jan 27, 2011 | 11:23 AM
DisplacedMic's Avatar
Default Good way to get the engine mount back on?
Hi all - so I took my driver side engine mount off last weekend for a timing belt replacement and i had a hell of a time getting it back on. eventually it was just dumb luck but i damn near lost a finger in the process.
Is there an easier way to do this other than just jacking the engine up and down until you just "Get lucky?"
thanks!
99 accord lx 4cyl
Old Jan 27, 2011 | 11:25 AM
g22cd5's Avatar
Supper Moderator
engine hoist
Old Jan 27, 2011 | 11:26 AM
IIRC, at least one of the studs is extra-long. You can start a nut onto that one, & use that to finish pulling the engine up.
Old Jan 27, 2011 | 06:23 PM
Or were you having an issue with the mount/engine being out of "line" front to back?
Old Jan 27, 2011 | 06:44 PM
ebarrera661's Avatar
Almost A Senior Member
Honda mounts, (especially the rear and passenger) tend to be a bitch! Might as well change everything u can while ur in there..
Engine hoist
Old Jan 27, 2011 | 07:57 PM
I would feed the bolt through the rubber part of the mount first and get the threads started.
Then raise the engine to push the threaded part on the engine bracket and start threading the nut on there. Finally get the bolt started.
I would probably tighten the nut/bolt then finally tighten the through bolt.
jcliett1976
May 28, 2012 10:15 PM
baer77
Feb 27, 2009 03:47 PM
thunder_x
Jan 10, 2008 07:03 AM
YeuEmMaiMai
Oct 17, 2006 02:53 AM
