Got a problem with 3rd brake light. Anyone?
Old Jun 4, 2008 | 10:55 AM
FULLYHONDA
Default Got a problem with 3rd brake light. Anyone?
2000 honda accord 2dr v6. 3rd rear brake light on window mount went out. guys at jiffy lube tried to replace bulb but said something along the lines that i would need a whole new housing unit b/c everytime they put the bulb in it stays lit when applying pressure, but once they remove their hand it goes down again. I saw a few units on ebay for 99 accords, will this fit a 2000 as well? any way to rig this toget it to work again? Thanks
Old Jun 4, 2008 | 11:59 AM
finch13's Avatar
Default RE: Got a problem with 3rd brake light. Anyone?
I would take it out and monkey with the contacts before buying a new/used one. Any light from a 98-02 Accord should fit fine.
Old Jun 4, 2008 | 01:33 PM
Fenix's Avatar
have the dealer look at it. im pretty sure they know more than the guys at jiffy lube. The bulb in mine blew a year ago and ive been driving around without it since. I think it looks cooler and havent gotten in any trouble with the "man"
Old Jun 4, 2008 | 03:00 PM
FULLYHONDA
Will the same light/housing from this model in 4dr fit?
Also I dont mind that its out, but can I even get pulled over for this? I thought by law you only need 2 brake lights and this is just a 3rd for cosmetic appeal, so maybe I could just pull the light/housing out so it looks like a light was never even there?
Old Jun 4, 2008 | 03:59 PM
finch13's Avatar
The 2 brake lights are you're parking lights with integrated brake lights, the high mount light is the one that tells others you are applying your brakes. Personally, it pisses me off when that light is out, especially on pick-ups. When the sun is hitting the back of the car just right, you can barely see if the lights are one, whereas the 3rd light is somewhat shaded and easier to see. Not sure what the law says, but I bet you $5 you get rear ended sooner than you know it.
Old Jun 4, 2008 | 04:25 PM
That third brake light is placed to be in your line of sight, so you can have more time to react to someone braking in front of you.
Old Jun 4, 2008 | 04:34 PM
nafango2's Avatar
i agree, the top brake light is the easiest way to tell if someones braking. the only way to tell by the rear lights is if you see the lights get brighter, as if the headlights are on those lights are on too, they just brighten when the top brake light is out.
i would take it to someone else too, theres a reason jiffy lube is an oil change place.
Old Jun 4, 2008 | 05:19 PM
falkore24's Avatar
TBL is required by law. &amp\\;amp\\;\\\\\\;nbsp\\\\\\; I don&amp\\;amp\\;rsquo\\;t trust mechanics ..... jiffy lube, dealer crooks, performance shops .... none!&amp\\;amp\\;\\\\\\;nbsp\\\\\\; I might pay a bit more for my work, but I know that my master machinist friend does my work right.&amp\\;lt\\;\\\\\\;br&amp\\;gt\\;\\\\\\;&amp \\;lt\\;\\\\\\;br&amp\\;gt\\;\\\\\\;For the record ..... Jiffy Lube may know how to do an oil change, but that doesn&amp\\;amp\\;rsquo\\;t mean they can do even that well.&amp\\;amp\\;\\\\\\;nbsp\\\\\\; Check to see if they wipe off the drip from the drain pan .... around the filter.&amp\\;amp\\;\\\\\\;nbsp\\\\\\; I highly doubt it.&amp\\;amp\\;\\\\\\;nbsp\\\\\\; Firestone is a tire place, yet they managed to screw up all of my buddy&amp\\;amp\\;rsquo\\;s rims mounting a set of tires, 40 series.&amp\\;amp\\;\\\\\\;nbsp\\\\\\; A/V electronics and tint place .... cr@ppy install of the alarm/remote starter on my Accord.&amp\\;amp\\;\\\\\\;nbsp\\\\\\; Same shop screwed up my buddy&amp\\;amp\\;rsquo\\;s tint on the EP3.&amp\\;amp\\;\\\\\\;nbsp\\\\\\; Specialists my keester!&amp\\;amp\\;\\\\\\;nbsp\\\\\\; I have 1 tranny specialist that I trust and 2 other people that can touch my car, Dan and me.&amp\\;amp\\;\\\\\\;nbsp\\\\\\; Next week I&amp\\;amp\\;rsquo\\;m trying out another AV shop for my tC&amp\\;amp\\;rsquo\\;s tint.&amp\\;amp\\;\\\\\\;nbsp\\\\\\; They are very highly regarded ..... we&amp\\;amp\\;rsquo\\;ll see how they do.&amp\\;lt\\;\\\\\\;br&amp\\;gt\\;\\\\\\;&lt\\;b r&gt\\;&lt\\;br&gt\\;WTF!!!&lt\\;br&gt\\;
Old Jun 5, 2008 | 06:03 PM
FULLYHONDA
I found a cheap on on ebay for a 2000 but its the 3rd light for a 4dr, mines a 2 dr. Will it fit the same? Thanks
Old Jun 5, 2008 | 10:12 PM
nafango2's Avatar
ORIGINAL: falkore24
TBL is required by law. &\\;amp\\;\\\\\\;nbsp\\\\\\; I don&\\;amp\\;rsquo\\;t trust mechanics ..... jiffy lube, dealer crooks, performance shops .... none!&\\;amp\\;\\\\\\;nbsp\\\\\\; I might pay a bit more for my work, but I know that my master machinist friend does my work right.&\\;lt\\;\\\\\\;br&\\;gt\\;\\\\\\;&\\;lt\\;\ \\\\\;br&\\;gt\\;\\\\\\;For the record ..... Jiffy Lube may know how to do an oil change, but that doesn&\\;amp\\;rsquo\\;t mean they can do even that well.&\\;amp\\;\\\\\\;nbsp\\\\\\; Check to see if they wipe off the drip from the drain pan .... around the filter.&\\;amp\\;\\\\\\;nbsp\\\\\\; I highly doubt it.&\\;amp\\;\\\\\\;nbsp\\\\\\; Firestone is a tire place, yet they managed to screw up all of my buddy&\\;amp\\;rsquo\\;s rims mounting a set of tires, 40 series.&\\;amp\\;\\\\\\;nbsp\\\\\\; A/V electronics and tint place .... cr@ppy install of the alarm/remote starter on my Accord.&\\;amp\\;\\\\\\;nbsp\\\\\\; Same shop screwed up my buddy&\\;amp\\;rsquo\\;s tint on the EP3.&\\;amp\\;\\\\\\;nbsp\\\\\\; Specialists my keester!&\\;amp\\;\\\\\\;nbsp\\\\\\; I have 1 tranny specialist that I trust and 2 other people that can touch my car, Dan and me.&\\;amp\\;\\\\\\;nbsp\\\\\\; Next week I&\\;amp\\;rsquo\\;m trying out another AV shop for my tC&\\;amp\\;rsquo\\;s tint.&\\;amp\\;\\\\\\;nbsp\\\\\\; They are very highly regarded ..... we&\\;amp\\;rsquo\\;ll see how they do.&\\;lt\\;\\\\\\;br&\\;gt\\;\\\\\\;<\\;br> \\;<\\;br>\\;WTF!!!<\\;br>\\;
holy crap
