Groan from power steering in sync with engine RPM
Old Nov 21, 2012 | 06:44 PM
misfit1981's Avatar
Default Groan from power steering in sync with engine RPM
2002 Accord 4cly
My power steering is making a growling noise in sync with the engine RPMs. The noise starts up as soon as the engine is cranked over. When I press the accelerator and raise the rpm's the groaning gets louder. When the rpm's settle aster start up the engine is struggling to stay at normal idle speed. The engine itself is t running, though. While stopped, when I turn the steering wheel the rpm's drop low and can cause the engine to stall, however the groaning noise doesn't change when the steering wheel is turned. Any help would be appreciated!
Old Nov 21, 2012 | 06:57 PM
Check the fluid level in the power steering reservoir. Also, look to see if there are air bubbles or the fluid is foaming.
Old Nov 21, 2012 | 08:16 PM
jroxz44's Avatar
Almost A Senior Member
It might be low on fluid. Or maby your power stearing pump is getting ready kill over. Also r u sure its your PS pump that's making the noise?
Old Nov 22, 2012 | 12:51 AM
holmesnmanny's Avatar
Spray something on the belt while the car is idling and if the sound goes away it's the belt too loose.
Old Nov 22, 2012 | 11:49 AM
jroxz44's Avatar
There is a adjuster useing the power steering pump. If the belt is fairly tight. Try taking a bar of soap and holding it to both sides of the belt. Just the sides. And only alittle. That will fix the whining of the belt if its that. Most people don't know belts should be washed with dish soap before putting them on. Especially snowmobile belts it allows them to grip better instead of slipping
Old Nov 22, 2012 | 04:37 PM
Remember old belts get hard & slippery with heat & age. Washing doesn't always fix that. If you overtighten them (rather than replacing) you're asking for bearing problems.
kompressor
May 29, 2014 07:46 PM
GMANCRX
Oct 10, 2013 01:03 PM
fvansan
Jul 23, 2013 01:06 PM
darkgreen18290
Jun 25, 2013 07:51 AM
old88dog
Jun 13, 2007 10:58 PM
