Ground switched or postive switched
Old Dec 19, 2008 | 10:03 PM
Tippman7641's Avatar
Default Ground switched or postive switched
As some of you know im a volenteer firefighter i am gettin a wig wag flasher system for my head lights
http://www.swps.com/whelheadflas.html
but i need to know if hondas are ground or postive switched, heres the install manual
http://www.whelen.com/install/135/13510.pdf
Old Dec 21, 2008 | 12:44 AM
Default RE: Ground switched or postive switched
You might want to put your year/model in your signature.
I think that they are positive switched.
You can use a volt meter to test this. With the lights off, probe each side of the plug to a good ground (like the engine block). If you find 12V, then it is ground switched.
If both sides show no voltage, turn on the lights. If you find 12V, then the lights are positive switched.
sTeVo!
May 21, 2006 04:58 PM
F23AccordLX
Mar 3, 2006 01:08 AM
F23AccordLX
Feb 24, 2006 05:24 PM
F23AccordLX
Feb 24, 2006 07:48 AM
theycallmerickjames
Oct 10, 2005 03:00 PM
