H22A Motor Swap
Old Apr 3, 2008 | 02:52 PM
eric123's Avatar
Default RE: H22A Motor Swap
Ok and how hard is it to remove the whole wiring harness from the car?
Old Apr 3, 2008 | 02:56 PM
ORIGINAL: eric123
not hard, just have to get to some tought spots, you just have to unhook all the sensors.
the only problem is if it is your daily driver, you will be without a car for a few weeks probably when you send it in to them.
the alternative is to get an accord wiring harness off ebay or from a junk yard or something that way you can still drive your car. but wiring harnesses are easily $100 on a ebay
Old Apr 3, 2008 | 03:17 PM
eric123's Avatar
Ok thanks alot for your help, that's it...for now. I'll post how it goes.
Old Sep 6, 2011 | 10:15 PM
roboaccord22's Avatar
i have a 97 accord ex coupe with obd2 1997 h22a in it and its misfires usually when im ust lightly holding down the gas (engine light flashes) but as soon as i let go it stops.... and for the accord there is a resister box for the injectors i belive by the driverside wind shield bolted to fender should that be plugged in for h22a
Old Sep 6, 2011 | 10:16 PM
im just stupmed and been trying to trace this for a while and btw im running on my f22b1 ecu because dumbasses sent me a p5m immobalizer usdm ecu
Woodall
Mar 4, 2014 04:21 AM
hitek85
Feb 12, 2008 10:32 AM
zelseman
Jan 19, 2006 05:57 PM
9JordonAccord9
Jan 10, 2006 06:13 AM
LinX
Nov 8, 2005 03:43 AM
