H22a wiring
Old Jul 19, 2011 | 11:21 PM
littledrakon's Avatar
Default H22a wiring
Hey guys im doing a h22a jdm obd1 swap on my 96 accord f22b1
And im having a little trouble with the wiring bcause the plug on the accord
Only has 5 wires n the h22a have two plugs with 10 wires how do i
Go about wireing this if you anyone can help me out i will appreciate it and one
More thng what do i do with the crank sensor plug? Thnks
Old Jul 20, 2011 | 12:06 AM
I'm sure other people have the same question so here is how to wire up an internal coil h22 distributor using an accord wiring harness.
Old Jul 20, 2011 | 01:35 AM
those are the plugs i cut off livetorice does it look correct?
Old Jul 20, 2011 | 08:36 AM
The left ones are the ones you need to use. Assuming you have the two for the wiring harness to match.
Then just run the wires from the timing case to the distributor and wire it up according to that diagram.
Old Jul 20, 2011 | 01:40 PM
Tek310's Avatar
does this apply to the obd1 f22b1 as well?
Old Jul 20, 2011 | 10:44 PM
Is imagine
hitek85
Feb 12, 2008 10:32 AM
Jahsaccordcoupe
Nov 14, 2007 10:56 AM
zelseman
Jan 19, 2006 05:57 PM
Shocker
Oct 8, 2005 05:38 PM
94hondaaccord
Mar 24, 2005 12:59 AM
