H23 tranny conversion on F23 motor
Old Nov 30, 2008 | 12:07 PM
Uneek
Default H23 tranny conversion on F23 motor
Ive read a bunch of posts saying the motor and tranny will come together with ease......problem is im trying to find out what all parts im gonna need to get the tranny hooked up and working properly.... I have a 01 accord with an automatic tranny.....as the title says i wanna do a h23 5 speed swap.....i know i need clutch master and slave a shifter and pedal and probably an ecu but what else do i need??? Thanks in advance
Old Nov 30, 2008 | 12:10 PM
Default RE: H23 tranny conversion on F23 motor
list is made for a 5th gen, but should be very similar
Parts list for auto to manual swap
1. 5 speed transmission (F22, F23, H22, H23)
2. 5 speed starter (90-02 Accord 92-02 Prelude)
3. 5 speed shifter assembly w/ shifter cables (90-97 Accord, 92-96 Prelude)
4. 5 speed drivers side axle (your year accord, but from 5-spd version)
5. 5 speed intermediate shaft (your year accord, but from 5-spd version)
6. 5 speed clutch pedal assembly (90-97 Accord, 92-96 Prelude)
7. 5 speed brake pedal arm (90-93 Accord, 94-97 Accord)
8. Clutch master cylinder w/ reservoir and lines (90-97 Accord 92-96 Prelude)
9. Clutch line from Clutch master cylinder to clutch dampener (90-97 Accord 92-96 Prelude)
10. Clutch dampener assembly (90-97 Accord 92-96 Prelude)
11. Clutch line from Clutch dampener to 5 speed tranny (90-97 Accord 92-96 Prelude)
12. Clutch line from 5 speed tranny to slave cylinder (90-97 Accord 92-96 Prelude)
13. Slave cylinder (90-97 Accord 92-96 Prelude)
14. Clutch (90-02 Accord 92-01 Prelude)
15. Flywheel (90-02 Accord 92-01 Prelude)
16. 5 speed mount (Your year, 5-spd version)
17. 5 speed mount bracket (go to Honda - tell them to look for the bracket that is welded on the car - part is S.O.P and costs 15-25.00) (see notes)
18. MIG WELDER (see notes)
19. BOLTS: 8 Flywheel Bolts, 6 Pressure Plate Bolts, 3 Intermediate Shaft Bolts, 1 Long Tranny Bolt
Old Nov 30, 2008 | 12:17 PM
Uneek
Thank You My car is a 5th gen isnt it??
Old Nov 30, 2008 | 12:23 PM
5th is 94-97 6th is 98-02 or is it 01 I can never remember.
Old Nov 30, 2008 | 12:30 PM
Uneek
your rite its 02 and that makes sense i didnt count the unknown 1st gen accord that u never see anymore
Slowone11
May 2, 2013 09:17 PM
g22cd5
Apr 25, 2013 08:59 AM
accordmatt
Oct 11, 2011 10:30 PM
alexdc
Nov 23, 2010 01:58 PM
littledrakon
Jan 18, 2009 02:11 AM
