Head bolt size
Got a couple head bolts rounded.. Not at home right now, at work, and a guy is going to let me borrow something to get it out with. Just need to know what size it is. Think it's a 9/16 but can't remember for sure.
Guarantee its not a 9/16 as nothing on your Honda is standard size. I'm not for certain as this is just off the top of my head but I think they are 14s. Basically everything except for a few oddballs on Hondas are either 8 10 12 14 or 17l
I would get an OEM bolt.
Many aftermarket bolts may not be correct strength. If you get a purposed "head bolt" you should be OK.
I also recollect 14mm socket size bolt. Bolt size from manual is 12mm x 1.25mm, so may be larger than 14mm socket size.
