head lamp lights on
Old Nov 17, 2008 | 01:34 PM
paulhenrick2k8's Avatar
Default head lamp lights on
guys, im having this problem. the "brake lamp" light is on on the dashboard. but i already checked the tail lights even when someone pressed the brakes, everything is working. anyone knows what the problem is?
Old Nov 17, 2008 | 01:36 PM
finch13's Avatar
Default RE: head lamp lights on
1. Possibly low on brake fluid.
2. Switch on the e-brake may be bent or non-functional.
Old Nov 17, 2008 | 02:31 PM
jcocker03's Avatar
yea definately check the brake fluid level, when the fluid level drops too low it sets off a sensor which turns on your brake light
Old Nov 17, 2008 | 02:37 PM
falkore24's Avatar
There is a DIY about notching the screen in the reservoir to eliminate the brake light. You should see if that applies to your model.
Old Nov 17, 2008 | 06:22 PM
harryharley's Avatar
Had the exact problem last week on my 99 accord lx.
It was about 2 oz. low in the brake fluid. Topped it off and all is well. Light off.
Used genuine Honda brake fluid too.
Old Nov 17, 2008 | 07:26 PM
Is this an inquiry about the brake light fault detection circuit, or red low brake fluid lamp? I think the former from his description.
If that isthe case, I've seen intermittent brake light bulbs cause this problem. Apparently filament is cracked and opens momentarily due to vibration, setting of the brake lamp out warning. New bulbs are necessary to fix. No way to inspect and find the faulty bulb.
Old Nov 18, 2008 | 02:22 AM
ORIGINAL: TexasHonda
yeah.. thats what i thought.. but let me also check the brake fluid.. thanks to all of u guys!
Old Nov 18, 2008 | 07:58 PM
The warning lamp for the fluid & handbrake are the same, which is the one that lights up when you pull the handbrake handle.
The one for burned-out brake lamps says BRAKE LAMP. It works by comparing wattage side-to-side. Some people have replaced all bulbs back there just so they match each other. Also, dont forget to clean out corrosion/dirt from the bulb sockets.
Old Nov 21, 2008 | 12:50 PM
really? oh well.. maybe i have some bulb problems.. coz when i use handbrake "brake" light is what i see in the panel and "break lamp" light is on since i bought it.. how much does bulb cost?
Old Nov 21, 2008 | 12:51 PM
man, i just figured out.. the title of this post is wrong.. my bad guys.. lol.. it should be break lamp instead of head lamp..
dmalay1
Jul 6, 2009 08:05 PM
bluemagic03
Nov 29, 2008 09:43 PM
paulhenrick2k8
Nov 18, 2008 02:23 AM
schmo1
Apr 12, 2008 05:25 PM
Aistisval
May 20, 2007 05:00 PM
