headlights: 9006 51W vs. 9006 80W
Old Aug 9, 2012 | 01:06 AM
darkgreen18290's Avatar
Default headlights: 9006 51W vs. 9006 80W
9006 51W are what come stock in my accord. i have bought 9006 80W, my question is the wiring harness can hold the temp and will not melt? Too Hot?
any experiences on this?
thanks
Old Aug 9, 2012 | 09:09 AM
Dr. Drivability's Avatar
any direct fit 9006 will work, the problem is (from experience) the brighter bulbs like the g.e. nighthawk and sylvania type won't last as long as they burn hotter = shorter life.
Old Aug 12, 2012 | 02:57 AM
is the wiring harness design to handle up to 100W?
Old Aug 12, 2012 | 10:21 AM
it's got nothing to do with the harness...the bulb filament determines the output of the light/heat. the harness delivers 12 volts regardless, the bulb does the rest. the harness is happily ignorant to what goes on inside the bulb...
Old Aug 13, 2012 | 12:41 AM
im curious with the harness of getting melt bec of the high watts of the bulb and burning too hot, so would like to know if the harness is capable of handling this type of bulb or it is only design to handle the stock 51W, on my previous car the harness was melt when i replace the bulb to a higher watts.
Old Aug 13, 2012 | 04:36 AM
joec44's Avatar
Default h lights
Way not rewire with a relay like a fog light ?
Old Aug 13, 2012 | 06:29 AM
UhOh's Avatar
Originally Posted by darkgreen18290
... so would like to know if the harness is capable of handling this type of bulb or it is only design to handle the stock 51W,
clear, well phrased question - as it was earlier. luck.
if you don't get a response within several days you'll have to do the experiment yourself.
I'd probably check temp by feel after 2 or 3 hrs of night driving.
hope you tell us the results...
Old Aug 13, 2012 | 08:29 AM
this car is a euro model, but all things being equal, the headlight circuit already has relays. that would "esplain" the broken "engrish" as well...
Old Aug 22, 2012 | 12:45 AM
update: after almost 2 hours of night driving the harness survived, however its very hot when i touch it.
doanutboi
Jul 2, 2008 08:31 PM
kreizyidiot
Nov 29, 2007 09:02 AM
kouken
Nov 11, 2007 06:48 PM
accordangel
Nov 1, 2007 06:32 AM
zspeedzkwy
Aug 12, 2007 08:34 AM
