hearing rattling under car over bumps
Old May 17, 2007 | 12:27 PM
maro's Avatar
Default hearing rattling under car over bumps
I'm hearing rattling when I hit bumps. It's coming from under the car. Sounds like it's close to the tires. Any clue?
Old May 17, 2007 | 12:44 PM
tkundert2's Avatar
Default RE: hearing rattling under car over bumps
When the car is cool (not just driven) reach under check for any loose items. Suspension components and tires you should be able to grab hard and try to shake and detect zero play. Things like exhaust you should apply a gentler touch.
Old May 17, 2007 | 04:35 PM
hondadude's Avatar
#2 the sway bar bushings, check to see if a flashlight can be seen thru them where they go around the sway bar.
Also check the sway bar end links, thereshould be4 rubber bushings
Old Jan 7, 2008 | 11:31 AM
unir2b1
I'm having this same issue and many sources have suggested checking the sway bar bushings. What is a reasonable price to have them replaced and is this a job that my friendly neighborhood mechanic can do or do you recommend going to a dealerwith Honda parts?
Old Jan 7, 2008 | 11:36 AM
sir_nasty's Avatar
it's a pretty simple job that anyone can do, I can't imagine them charging more than an hours labor and the bushings themselves probably aren't more than $10 each. If you can't get it done for under $100.00 parts and labor I'd be stunned.
Old Jan 7, 2008 | 01:01 PM
unir2b1
If I'm pretty handy but not a mechanic per se, can I do it? Are the sway bars under tention or anything? It's not like dealing with shocks/struts, right? I change my own oil...I'm not afraid to get under the car.
Old Jan 7, 2008 | 01:06 PM
sir_nasty's Avatar
pretty simple and straight forward, a few bolts off a few bolts on... If you change your oil you should be able to do it, with the car on a level surface it should be fine.
atsioukl
Aug 17, 2009 09:11 AM
rkelly_83543
Apr 24, 2009 03:33 PM
thunder_x
Dec 10, 2007 10:24 AM
manual123
Dec 1, 2006 01:46 AM
deserthonda
Sep 5, 2006 02:57 AM
