Heater control ground location?
Old May 22, 2015 | 01:44 PM
BlackLX4's Avatar
Default Heater control ground location?
Our Accord has a bad heater control. There's power but no continuity. Can somebody tell me where the ground is? I really hope it's not the wire itself as I really don't want to dig through the harness. Thanks in advance!
Old May 22, 2015 | 02:03 PM
What year, model trim?
You can include you car's info. in the signature or each thread.
Old May 22, 2015 | 10:34 PM
BlackLX4's Avatar
1998 Accord LX, 2.3L VTEC/4AT.
Old May 23, 2015 | 07:58 AM
G401 is the gound for the heater control "panel"....it is also the ground for many other things so it is a bit strange that more than just the heater control panel is not getting ground to "pin #9" on the connector for it
Behind the left kick panel, you should see a bolt to the body with a mess of wires connecting to it.
Attached Thumbnails Heater control ground location?-6th-gen-g401-location.jpg
Old May 23, 2015 | 08:48 AM
These are some photos of G401. It is above the kick panel; so, it is not necessary to remove the kick panel to see it. You may have to remove the dash under-cover though.
Old May 23, 2015 | 08:52 AM
The man with the best pic's......
Old May 23, 2015 | 09:02 AM
I agree with Poorman212 that it is it is also the ground for many other things so it is a bit strange that it is not more than just the heater control panel with issues.
Further testing is needed. Where is there no continuity (e.g., which wires, power or ground, color of wire(s), etc.)?
Old May 23, 2015 | 10:19 AM
BlackLX4's Avatar
It's the black ground wire to the #9 pin on the heater control connector.
Old May 23, 2015 | 10:39 AM
The leads of the volt meter should be long enough for you to check continuity from Pin #9 of the connector to the ground bolt (g401). No sure what you were using before, could have been a weak coonection.
Note, the manual HVAC control panel on the 6th gen Accord's will go bad. There are a few write ups on here on "how to repairs".
Old May 23, 2015 | 10:48 AM
BlackLX4's Avatar
Okay, so I found the G401 and checked again for continuity, and there was nothing.
Basically what has happened is that it has slowly gone bad. It started out being really flaky and it wouldn't always work, and the lights that were on at that particular moment on the control panel would flicker and we would hear a clicking/snapping sound that went along with the flicker. Then it totally died a few days ago, and what really sucks is that it's stuck on hot air, so always blows hot air even with the dial set to cold. NOT something we want to be stuck with when the summer weather hits!
