Heater Hoses ?
Old Oct 31, 2024 | 07:40 PM
btartus's Avatar
Default Heater Hoses ?
1995 Honda Accord 2.7L
I am looking to change the heater hoses as they are original and dont look very good. I have found 3 hoses for the car on Gates Website.
1. Heater to Valve-1
2. Heater to Thermostat
3. Valve-1 to Intake Manifold
so my question is, do I replace all of them? total costs for the 3 is $100. I figure Gates hoses will work well. any other suggestions?
Old Oct 31, 2024 | 09:33 PM
75Gremlin's Avatar
If all three don't look good, I'd replace all. Otherwise just replace the hoses that are either hard or very soft or bulging. Gates is good and should give many years of service life.
Old Oct 31, 2024 | 09:41 PM
I remember the picture from your previous post, so I'd replace all of them. Gates should be fine.
Old Oct 31, 2024 | 09:45 PM
btartus's Avatar
ok, well I can really only see the one clearly going into the firewall and it needs replace. I posted a picture the other day, so I have to assume the other 2 should be changed as they are all original hoses. amazing they have lasted in Florida so long but Honda parts, the best!
so I will go with Gates! thank you very much! Rock Auto has 1 for $17 and another for $22. $8.99 ship. best deal on these I have found. ordering now.
so do you think its smart to replace the Radiator hoses while im flushing the system? they are not original. I installed a new Radiator and hoses January 2018. so the hoses are 7 years old.
thank you!
bryan
Old Oct 31, 2024 | 09:58 PM
75Gremlin's Avatar
It's usually the top radiator hose that goes bad first due to the hot coolant going through it to the radiator. Often the bottom hose will last a few years longer than the top, assuming they were the same quality. If the top hose isn't hard or soft or bulging, that's a good sign and it should still be ok. You could remove the top hose and inspect the inside also and if it still feels like a new hose then you will probably be fine. Sometimes I just replace the top hose. Hoses these days last much longer than when I was young. The OEM honda hoses were excellent quality and could last over 20 years.
Old Oct 31, 2024 | 10:11 PM
btartus's Avatar
great! I will just get a new Top Hose as the one now is 7 years old and been through many hot summers here in Florida. so it cant hurt and im a big fan of inexpensive steps of prevention.
thank you!
bryan
Old Oct 31, 2024 | 10:18 PM
btartus's Avatar
I just ordered a top Radiator hose Gates $27 with Ship from Partsgeek. last one they had. I will have my mechanic inspect the bottom radiator hose before he flushes system and if he says to do the bottom ill get that one last.
do you recommend buying new radiator hose clamps or the originals hold and never fail in your experience? Im assume they last forever but I though I would ask.
Old Oct 31, 2024 | 10:21 PM
btartus's Avatar
now ill tell you my story. 7 years ago I installed a new radiator and 2 new hoses. the next day the top hose blew 1/2 inch hole in it. I looked at the hose that was installed. made in China. Ha. so I switched it to a Made in USA part and its 7 years later.
bryan
Old Oct 31, 2024 | 10:29 PM
btartus's Avatar
thanks buckaroo! thats the plan. all 3 hoses ordered + a new top radiator hose. all Gates. got them all for $100. happy happy!
would you change the 7 year old lower Radiator hose for the sake of doing all the others, just for peace of mind? I can have my mechanic inspect it, but what would you do?
Old Nov 1, 2024 | 07:37 AM
75Gremlin's Avatar
[/QUOTE]
do you recommend buying new radiator hose clamps or the originals hold and never fail in your experience? Im assume they last forever but I though I would ask.[/QUOTE]
those OEM hose clamps last "forever" unless damaged or rusty. I've always reused them and prefer over the worm gear clamps
