HELP!!!
Okay, car: 1996 Accord sedan, f22b2 engine.
Problem: I have installed a race header, (straight pipe, no cat). I have a cel, pulled the code and got #65(Secondary oxygen sensor heater wire.) I tried to reset it, but it still is on. Any ideas what can be wrong? I have no experience with the accord, only my rsx. On the rsx, you can use an 02 simulator to get rid of the cel light(if you dont the car goes into limp mode, and I dont want that to happen with the accord, its my daily driver.)Im not sure if the same applies to the accord. Please help. Thanks in advance.
It's because you don't have a cat. You will have to find some kind of o2 sensor simulator like you said you had for your RSX, or you will have to install a cat to get the CEL to go away.
http://www.optionimports.com/o2siadcelfix.html
Seems like this could work.
.... or this
http://www.o2simulator.com/index.php...;products_id=9
.... or this
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
