HELP! 2003 Accord Weird Starting Issue
2003 Accord Sedan 4cyl Automatic
When we try to start it it seems like the battery is either low or drained. REAL sluggish... In some cases it does not start at all (like a dead battery) but the battery is brand new and reading over 12 volts. When it gets to the point of not starting at all, I put the car in neutral and this seems to help sometimes. Running the shifter in and out of park seems to help. Yesterday it was cold (in the 40's) and it really had a hard time wanting to start... I noticed a buzzing sound, like the starter clicking or a relay buzzing and the "D" light came on for a few seconds while it was trying to start. I am at a loss... local auto parts store says it needs a new starter (but then again they are the ones that at first said it was the battery and sold me a new one) I read it might be a "Neutral Safety Switch" or a "Main Relay" Any help at all is much appreciated. |
Check, clean and tighten all connections of the battery cables. If you have a volt meter, after cleaning everything, check the voltage drop at the starter......
I would agree w the NSS or Main relay possibilities. Had a buddy with a bad main relay w similar symptoms. Think it was like $50 and minutes worth of labor.
Thank you for the help! Car is fixed!
I checked the main relay and all connections first... apparently you can listen to the number of clicks coming from the relay as you turn the ignition and it checked out... see below: TROUBLESHOOTING THE MAIN RELAY You may read the FAQ for more basic troubleshooting, otherwise just follow this troubleshooting flow chart before performing the main relay bench test. The main relay typically fails in three ways.
http://www.driveaccord.net/forums/at...9&d=1234458460 http://www.driveaccord.net/forums/at...8&d=1234458339 Thanks again everyone for the help! |
