help??
Old Apr 6, 2006 | 06:58 PM
dsloan04
Default help??
hello, can someone help me out.. i'm working on my 91 honda accord dx model.. and i'm installing a 96 h22a type s motor.. with the tranny.. as far as the accord f22 engine harness... that harness i can use right... one thing is that i have to run my vtec wiring and knock sensor.. right???
Old Apr 6, 2006 | 07:10 PM
sir_nasty's Avatar
Default RE: help??
Someone will probably be along shortly to answer this question but until then check out www.f22parts.com they have conversion harnesses w/free tech support available... Might make life easier!
Welcome to the forum and good luck on the swap that sounds sweet!
Old Apr 6, 2006 | 07:13 PM
dsloan04
Default RE: help??
THANKS....
Old Apr 7, 2006 | 05:57 AM
lightshow's Avatar
Default RE: help??
no just use a h22 harness and for sure use a h22a computer. call hasport they can help you with some answers. wiring the vtech is not easy and i wouldnt suggest it unless you are a very good electrician. i would not attempt it myself
Old Apr 7, 2006 | 07:39 AM
jinkamasaki
Default RE: help??
I need help too!!!
lol
I have a 1993 Honda Acoord LX Sedan
Auto transmission.
Um...what do I need to get checked if when I press my brakes my parking lights come on. Also...at night when I turn on my headlights the first time I press the brakes the brake lights stay on. My friend told me there is a switch somewhere around the brake pedal that I need to turn off or something. Where is that and how do I do it? Is this my solution? And I am also getting the brake lamp light in the dash. not cool. Please help.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
