help
I need some help guys. A friend of mine has a 97 accord. It seems to drive fine MOST of the time, but her Tach bounces from 0- 4k rpm as she's driving, and then everyonce in a while it will cut out just a bit. Not terribly bad, but it will stall just a little. I don't know much about the car, but she said she did change the spark plugs within the last year. Other than that I know nothing. Any help would be greatly appreciated.
Forgot to add, its a 97 accord EX V6. |
RE: help
test the ignition module. is the car tossing any codes? how does the coil test out?
RE: help
ORIGINAL: specsen I need some help guys. A friend of mine has a 97 accord. It seems to drive fine MOST of the time, but her Tach bounces from 0- 4k rpm as she's driving, and then everyonce in a while it will cut out just a bit. Not terribly bad, but it will stall just a little. I don't know much about the car, but she said she did change the spark plugs within the last year. Other than that I know nothing. Any help would be greatly appreciated. Forgot to add, its a 97 accord EX V6. does the tack jump as car is cutting out ? or does tach jump all the time ? does chk engine lite come on ?? if so, we need to know the code ( s) that is ( are ) stored .. |
