Help!
Old Jun 8, 2011 | 08:39 PM
jelly53's Avatar
Default Help!
hey guys, i have 2004 Accord V6 w/ 56000 miles. Basically I'm having missfire issue, whenever I go WOT (wide open throttle) the check engine light flashes 5-6 and then goes off. when i floor it again the check engine flashes but this time it stays on. i pulled the codes p0301, p0305, and p0300. today i changed the plugs and after that i went WOT and again the check engine started flashing. the engine idles normal and if i drive normal, the car drives fine. so what could it be coils? injectors?
thanks
Old Jun 8, 2011 | 10:21 PM
Tek310's Avatar
P0300 Random Misfire
P0301 No. 1 Cylinder Misfire
P0305 No. 5 Cylinder Misfire
what kind of plugs did you put in? did you gap them properly if they required gapping?
how do your plug wires look?
also where do you get your gas? fuel filter changed within last 20,000 miles?
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
