Help!!!
Old Apr 4, 2012 | 10:35 AM
johneeewalker's Avatar
Default Help!!!
i have a 94 accord automatic. transmission problem. checked code, it is
#8. Faulty wiring / short, tranmission **** contrl soelnoid B. Replaced solenoids, still getting same code. What to do now?
Old Apr 4, 2012 | 03:27 PM
posativJ311's Avatar
I seen that code before on a different car, and it was the wiring itself. What I would do is I would check the wire that goes to the solenoid. Check it to make sure that its even connected and that its not cut or open to where you can see the wires or grounded somewhere.
Are there any other check engine codes besides that one?
Old Apr 5, 2012 | 06:17 PM
Be sure to check the connector as well, I've seen where the pins inside the connector get dirty and will not make good contact.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
