Help
Old Jan 19, 2013 | 10:57 AM
jron's Avatar
Default Help
Hi hope someone can help.
I'm trying to replace the spark-plugs on my 2000 accord v6 and one of the ignition coil is stock won't come out. What can I do to remove it. Thanks
Old Jan 19, 2013 | 01:51 PM
If this is Coil-over-Plug, have you removed the bolt holding the COP down?
It may take a bit of force to separate the COP from the plug.
Old Jan 20, 2013 | 09:49 AM
jron's Avatar
The coil head broke it was hard to remove the rest but I was able to do it. Thanks for your respond
Old Jan 20, 2013 | 06:48 PM
I'd put a bit of dielectric grease there so it doesn't stick next time.
Old Jan 21, 2013 | 04:29 AM
jron's Avatar
I will thanks for the info.
Old Feb 4, 2013 | 08:07 AM
jron's Avatar
Default Oil Pressure light is on car wont start
update
i was able to replace the ignition coil. car was running fine until this morning,
now the oil pressure light is on and car won't start, i check the oil level is fine, can anyone tell me what to look for any idea what is the problem.
Thanks,
Old Feb 4, 2013 | 10:30 AM
shipo's Avatar
Originally Posted by jron
update
Thanks,
Hmmm, two comments:
  1. The oil pressure light has no bearing on the no-start issue; when the engine starts, the light will (or at least should) go out.
  2. Sounds like you have an electrical issue; I'd start by going over everything you touched during your recent maintenance activities.
Old Feb 4, 2013 | 11:40 AM
Oil pressure light is usually a faulty oil pressure switch.
Regarding starting, do the Check Engine, Alt, Oil Pressure lights come on when keyswitch is turned to On?
Old Feb 4, 2013 | 01:18 PM
shipo's Avatar
Are you suggesting that cranking the engine with the starter alone can generate enough oil pressure to extinguish the oil pressure light?
Old Feb 4, 2013 | 06:19 PM
I wasn't sure that oil pressure light and no-start were simultaneous events.
Yes, prolonged starting revs might cause oil pressure light to go off. Switch closes at only a few psi of pressure. I don't know this for certain. It may that in Start postion, oil light is held on?
