help....
Old Apr 9, 2013 | 01:34 PM
aloha_bruddah's Avatar
Default help....
question, i have a antifreeze leak at the connection from the upper hose to the engine block.......i think this is the correct diagram. I need the gasket, would that be #8 in this pic? Should I just tighten up the water outlet? I did loosen it, but i thought i tightened it.......what do you think??
Old Apr 9, 2013 | 02:06 PM
shipo's Avatar
Yup, it looks like #8 is the gasket. While you're in there you might want to replace the thermostat as well; often times new thermostats come with a gasket.
Old Apr 9, 2013 | 02:51 PM
Dr. Drivability's Avatar
the thermostat and o-ring are no. 5...no. 8 is just a seal for the engine inlet, the stat is the outlet. which one is leaking?
Old Apr 9, 2013 | 02:58 PM
#8 is leaking, where the upper hose goes from the radiator to the 'outlet'??? There is a sensor in this connector too....i know where the thermostat is, i've already changed that......thanks for the replies...i'm pretty sure #10 is the outlet that the upper hose connects to..
Old Apr 9, 2013 | 03:27 PM
shipo's Avatar
Yeesh, shows that I know.
Old Apr 9, 2013 | 03:47 PM
Yes, #8 is the gasket for the upper hose nozzle. But that "gasket" is really a type of O-ring, so overtightening the bolts will do ABSOLUTELY NOTHING about leaking (might even break off the tabs on #10). It's probably that the gasket has gotten hardened with age & heat, so it isn't going to seal.
Make sure it's the gasket that's leaking, as opposed to the hose clamp connection.
Incidently, that "sensor" is a fan-switch that has authority to switch the fan after you shut off the engine. #14 is the fan switch while it's running.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
