Help
Old Jun 6, 2016 | 01:13 PM
Liltoler's Avatar
Default Help
I have replaced the timing chain on my 2007 Honda accord, I have no bent valves and I don't have compression. What will cause this?
Old Jun 6, 2016 | 06:16 PM
Need some more information. Did the original chain break, or severely jump time?
How did you verify you don't have bent valves?
Old Jun 6, 2016 | 06:36 PM
Liltoler's Avatar
Originally Posted by PAhonda
Need some more information. Did the original chain break, or severely jump time?jumped time did not break.
I had my mechanic look at the head.
Old Jun 8, 2016 | 10:54 AM
Old Jun 8, 2016 | 11:55 AM
Liltoler's Avatar
Default Reply again
Just jumped time
Old Jun 8, 2016 | 06:31 PM
Not much can cause compression loss when the timing chain jumped. Either your timing chain is installed out of time, or you have valve damage.
You need to remove the valve cover, then verify the timing marks line up on the camshaft when you set the crank to top dead center.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
