Help
Old May 14, 2021 | 02:52 PM
dspeller's Avatar
Default Help
What should I do if both tail lights won’t work but the brake lights do
Side Note- I went to change the tail light bulb but it didn’t need to be changed
Old May 14, 2021 | 03:18 PM
shipo's Avatar
Are there any other lights not working? If so, it sounds like a wiring harness issue. My (former) 2001 Accord had this issue, a squirrel decided the plastic in the wiring harness was tasty and chewed it up.
Old May 14, 2021 | 03:24 PM
dspeller's Avatar
Front head lights work & brake lights work
Old May 14, 2021 | 03:45 PM
Year, model, trim level would help.
Old May 15, 2021 | 02:37 AM
FullCircleXpw's Avatar
Not trying to be a contrarian but I would double check if its a double filament.
in any case if both sides stopped working at the same time I would start by verifying the it even works by applying power as close to the bulb in the circuit as you can. Then trace your way back to the switch checking for shorts or damaged/burned wire.
BillieJackFu
Nov 19, 2014 12:42 AM
Porkchop37
Oct 30, 2013 12:43 AM
pham9006
Jul 9, 2012 09:33 AM
jhamilton
Mar 19, 2011 12:04 AM
poyp0ypnoy
Feb 3, 2007 03:50 PM
