Help with 98 Accord V6
Old Sep 14, 2009 | 07:17 PM
PJDiesel
Default Help with 98 Accord V6
Got a new (to me) accord. Here's the deal
Car sat for several months (from March til now). Ran perfectly fine when parked.
Now, I seem to be getting NO fuel to the injectors for some reason. If I give it a short shot of ether, it stumbles for a few seconds. Spark looks decent enough at the plugs.
I pulled a hose before what I think is the FP regulator in the engine bay, squirts a full flow of fuel, seems adequate.
Where should I start, main relay? Trying not to throw parts at it if I can help it.
Thanks in advance for any ideas......
Phil
Old Sep 15, 2009 | 01:49 AM
It sounds like you have a fuel delivery problem.
Listen for the fuel pump to turn on for ~2 seconds when you first turn the key to the II position in the middle of the clicks.
When the key is in the II position, the injector electrical connectors should have 12V on one of the two wires. The 12V wire should be the same color on each injector. The ECU grounds the other wire to allow the injector to open.
Old Sep 15, 2009 | 08:30 PM
PJDiesel
I can hear the pump "whilrling", then the "click" from under the dash.
I'll check the connectors at the injectors when I get a chance.
Thanks for the tip.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
