help- accord 2000 4cyl. tranny drain
hi
i wanted to drain the atf but rounded and destroyed the rectangular hole in the drain bolt. what's next? anyone had luck to open it with a pipe wrench or something? thx |
Probably time to get professional help.
Or if you have a welder, weld a large nut to the bolt. IMO, a large ez-out will only round the hole further due to shallow depth of hole. Maybe enough edge on the flange of the bolt to grip w/ vise grip? good luck |
Originally Posted by Eran Teitelbaum
(Post 380356)
hi
(Post 380358)
Or if you have a welder, weld a large nut to the bolt. good luck |
Won't hurt the trans but replace all ATF. ATF will be damaged from weldlng heat.
good luck |
when I do something like that I spray it with pb blaster and let it soak for an hour. After I bang the next size in and get it off. Hasn't failed me yet. If you try it make sure you have a replacement. If it's like all other accords I can't see how the whole bolt is stripped to the end
