-   -   HELP EGR Valve System (https://www.hondaaccordforum.com/forum/general-tech-help-7/help-egr-valve-system-4024/)
HondagalGA Jul 13, 2006 11:21 PM
I wrote before regarding a EGR problem with my 1999 Honda Accord, EX V6, Fuel-Injection. I really need your help again. The car has the PGM-FI light lights up with a DTC 12. I understand this code refer to a EGR problem. Recently, I changed the EGR valve and its lift sensor (they come together in one piece).
After I installed the new EGR valve and start the car again, the light was gone. I thought I fixed the problem. However, when I took the car out for a test drive, the light came up again after several minutes of driving. Now, the EGR problem still exists. What else should I do diagnose which part of the EGR system is having problem? How many components are involved in the EGR system for this car? If possible, would you please send me a complete instruction on how to check each components in order to find out the problem?
Chiovnidca Jul 14, 2006 12:11 AM
RE: HELP EGR Valve System
Did you clean out the egr port under the intake manifold?
HondagalGA Jul 14, 2006 12:37 AM
No. I haven't. What would I use to clean it?
deserthonda Jul 14, 2006 02:34 AM
how many miles on your car ?? honda was helping people with this issue till 80k ............
there is a egr flow kit that honda sells ,, you need to remove the intake manifold, drill the egr passage bigger and install this tube provided in the kit,, it might be somethig that you might want the dealer or a shop that specializes on hondas do..
if you do not want to install the kit,,,,,,,,just remove the manifold and clean the passage , use a sharp object , carb cleaner to brake all the carbon and compressed air to blow it all out ,,
HondagalGA Jul 14, 2006 08:50 AM
i have 140, and change
HondagalGA Jul 16, 2006 03:54 PM
Ok i have cleaned it out with the carbon cleaner. Now should the CEL flash after the cleaning has occured?
deserthonda Jul 16, 2006 08:17 PM
did you remove the intake manifold and clean out the passage ??? if not it is not properly cleaned , carbon cleaner alone will not do a good job...........the cabon in the intake passage might be so bad you got to brake it up with a sharp object , ( it has been thst way on the ones i have done ).......
Once cleaned properly, reset the ecu and drive it,lite should not come back on
HondagalGA Jul 19, 2006 11:36 AM
Thanks to all for your help. Problem fixed.
nixalot Jul 19, 2006 07:07 PM
:eek:
Hmmmm... any chance we could get a rundown on what ultimately fixed your problem?
HondagalGA Jul 27, 2006 05:00 PM
I needed to clean the egr port that was under the manifold.
