Help with inside Driver Door Handle 1999 EX-V6 Coupe
My inside door handle isn't working...I have to roll down my drivers side window and open my door from the outside.. Do I need to replace the handle? Or is something just loose?? And how would I fix this problem??
thanks in advance |
RE: Help with inside Driver Door Handle 1999 EX-V6 Coupe
the only way to know is to take off the handle and look. Its very easy to remove the door handle. 1 or two screws and it should pull out fairly easily. bear in mind it should be connected to the door latch via a metal-rod ish thing.
x2, it's acutally a flexible cable. if the cable anchor is broken at the handle or latch the door won't open from the inside.
