Help with inside Driver Door Handle 1999 EX-V6 Coupe
My inside door handle isn't working...I have to roll down my drivers side window and open my door from the outside.. Do I need to replace the handle? Or is something just loose?? And how would I fix this problem??
thanks in advance
thanks in advance
the only way to know is to take off the handle and look. Its very easy to remove the door handle. 1 or two screws and it should pull out fairly easily. bear in mind it should be connected to the door latch via a metal-rod ish thing.
jza240sx
Apr 30, 2013 04:14 PM
nismogrendel
Feb 7, 2013 07:03 PM
iridebmx33
Sep 23, 2006 01:38 AM
