Help with inside Driver Door Handle 1999 EX-V6 Coupe
Old Jan 21, 2008 | 04:38 PM
spazz
Default Help with inside Driver Door Handle 1999 EX-V6 Coupe
My inside door handle isn't working...I have to roll down my drivers side window and open my door from the outside.. Do I need to replace the handle? Or is something just loose?? And how would I fix this problem??
thanks in advance
Old Jan 21, 2008 | 04:55 PM
nafango2's Avatar
Default RE: Help with inside Driver Door Handle 1999 EX-V6 Coupe
the only way to know is to take off the handle and look. Its very easy to remove the door handle. 1 or two screws and it should pull out fairly easily. bear in mind it should be connected to the door latch via a metal-rod ish thing.
Old Jan 23, 2008 | 07:19 PM
HondatechAV6's Avatar
x2, it's acutally a flexible cable. if the cable anchor is broken at the handle or latch the door won't open from the inside.
jza240sx
Apr 30, 2013 04:14 PM
nismogrendel
Feb 7, 2013 07:03 PM
RicoCB3
Jan 25, 2013 04:23 AM
EXV6
Jul 27, 2007 12:41 PM
iridebmx33
Sep 23, 2006 01:38 AM
