Help! MAF Sensor?
Old Feb 7, 2010 | 10:49 AM
rtran19's Avatar
Default Help! MAF Sensor?
Hey everyone i need some help on my 99 accord. When i start it in the morning as i let it warm up, the rpm gauge jumps between 1000-1500 rpms. you can hear it as if someone was reving the engine. a buddy of mine says its make likely the maf sensor gone bad. any ideas guys? your response will be GREATLY appreciate it.
Thanks guys
Old Feb 7, 2010 | 11:22 AM
hondadude's Avatar
Well there is no Mass Airflow Sensor on Hondas. MAP Sensor = Manifold Absolute Pressure. Reads Vacuum
Check to be sure the coolant is full and the block burped of air.
I'm pretty sure that 98 and up V-6 use the Idle air Control Valve thru the PCM to change the idle speed for coldstart.
So a quick check is to unplug the IACV at idle to see if the RPM surge stops.
The IACV has a screen on it that can get plugged up, blast it with Carb Cleaner, I've also seen the valve itself stick, so compressed air and carb cleaner will help.
Other causes are vacuum leaks and if some one messed around with the idle air screw.
tysonmccrary
Sep 7, 2010 07:21 PM
pham9006
Sep 2, 2009 04:10 PM
ochondakidd
Sep 10, 2007 04:12 PM
accords own
Aug 13, 2007 01:58 PM
03AccordEX
Aug 12, 2006 12:40 PM
