help needed
Old Apr 29, 2011 | 10:42 AM
jricher's Avatar
Default help needed
Hi everyone
I have a '03 Accord sedan, 6 cyl AT with 76,000 miles. If driven in a normal no rush way, everything is good. However, when power is requested by flooring the gas pedal, and as RPM rise, you begin to feel a vibration on the car. This vibration stops as pedal is lifted. Transmission works ok, shifts up and down perfectly and no code is read on the handheld computer (don't know its name) when connected to the port. Any idea ?
Old Apr 29, 2011 | 02:41 PM
Most likely a damaged motor mount. I've also heard that a CV axle can cause this due to loose, worn parts in axle. I supsect mount is more likely.
If you eyeball the mount, have someone you trust set e-brake and hold brake firmly while goosing (1500-2000 rpm) the engine in drive and reverse as you inspect from one side of the vehicle. You may be able to see the mount separate.
Old Apr 29, 2011 | 03:36 PM
jricher's Avatar
Thanks TexasHonda
Will follow your recomendations and post any result...
mamtsberg
Mar 17, 2010 09:15 PM
csweet
May 20, 2006 02:09 AM
45auto
Apr 10, 2006 05:06 PM
Taggart
Feb 15, 2006 12:35 AM
calenatar
Feb 14, 2006 06:36 PM
