Help needed. Engine swap.
Old Jul 1, 2016 | 09:32 AM
sayahjames's Avatar
Default Help needed. Engine swap.
I have a 96 accord 2.2l vtec obd2 and I just picked up a parts car that is a 95 with the intent to swap the engines over but the 95 is obd1, is there a obd1 to obd2 connector for an automatic transmission, or would I be able to just change the Ecu and harness over?
Old Jul 2, 2016 | 07:43 AM
There are several ways of doing this. Yes, I believe that there is a "harness" that can be bought from aftermarket companies that will make the change a "plug and play".
The biggest thing you have to solve for, on the OBD-II one of the sensors for the dist moved to the crank gear vs the OBD-I where they are both inside the dist.
Old Jul 2, 2016 | 01:07 PM
I'd suggest trying to keep your OBD2 setup in your car, because you can do more diagnosis with and obd2 scanner.
You would have to use the distributor, oil pump/housing, and the crank gear from your 96 on the 95 engine. I think the transmissions are pretty much the same between the two cars.
Old Jul 3, 2016 | 06:26 AM
^Yes, I agree that OBD-II is better for many reasons....big one is car inspection laws in many states will force this.
All I was stating was there are differnt ways to get there.
1. Yes, you can swap the pump/housing, gear, sensor, ect from the 96 engine to the 95 engine.
2. Run the OBD-I dist and wire it to the OBD-II harness. There are companies that sell a harness that will be a plug and play thing or you can wire it yourself.
Or other means
Levibyz
May 31, 2011 09:43 PM
mfskarphedin
Jun 6, 2010 09:33 PM
mamtsberg
Mar 17, 2010 09:15 PM
StatzFinest
Feb 10, 2008 11:32 AM
