help plz
Old Mar 14, 2013 | 12:27 AM
matthew89's Avatar
Default help plz
hi i have a 1995 ex accord when i start driving rmp hit 3 the cel comes on then a few min latter u can hear the mfr click then d4 light flash and it revs out at 3 half i changed ecu tcu distributor ground wire from the battery and vtec solenoid plz help
Old Mar 14, 2013 | 12:29 AM
matthew89's Avatar
cel code shows 21 and trans is code 14
Old Mar 14, 2013 | 08:57 PM
So, address the codes? the 21 from the cel is for the vtec- low oil, bad pressure switch, clogged screen to the solenoid and a few others.
The 14 from the ecu is a bit if a concern.......testing could prove the tcu is bad.
Old Mar 15, 2013 | 01:14 AM
matthew89's Avatar
oil level is good just installed a new vtec oil pressure switch and wen i did that i also clean the whole vtec billet screen and everything and still the same thing i noticed the vtec solenoid tens to get really really hot and also the main fuel relay gets really hot as well i cleared the code and it came back and dose the same thing
Old Mar 15, 2013 | 08:37 AM
The single wire and connector to the vtec solenoid can be easy to damage (guess how I know this).
However, after repairing the wire, I had code 21 again. I checked solenoid resistance at ECM connector under the dash and got acceptable resistance (14-30 ohms). Used ECM from salvage yard fixed problem.
Trans code 14 can also be a ECM/TCM fault.
Old Mar 15, 2013 | 10:37 PM
matthew89's Avatar
ok thanks going try text um now
Old Mar 15, 2013 | 11:13 PM
matthew89's Avatar
ok vtec solenoid un plug got 17 ohms the other side not connected got 35 ohms is that good
Old Mar 16, 2013 | 12:06 AM
Can you explain your last post better. It makes no sense.
Old Mar 16, 2013 | 12:29 AM
matthew89's Avatar
Sorry. Vtec un pluged test the wire going to ECM and is showing 35.0 ohms then I tested just the vtec solenoid and its showing 17 ohms
Old Mar 16, 2013 | 09:10 AM
Resistance test must be performed on the connector at the ECM/harness connector under pax side of dash. Reading is between correct pin and local ground.
The 35 ohms reverse reading has no meaning since ECM is connected.
