help setting clock on 2001 Accord, please.
hi
just bought the car, the small clock face plate is "fogged" , when I press the H to set the hour, nothing happens, when I press the M to reset the minutes, that works.
When I press the R to reset to nearest hour, nothing happens.
Any suggestions appreciated.
(Radio works perfectly)
thank you
jerry whitfield in North Carolina
thank you
You might try getting a replacement clock from a junk yard. It really shouldn't cost that much, and you're looking at the same amount of work (basically) as changing the bulb in it. Just a thought since yours has a fogged over face. I only say that, as you were trying to set the time correctly.
sXyGolden
Apr 22, 2008 03:52 PM
baileyismyhero
Feb 13, 2008 10:57 AM
