Help- what does this code mean?
Old Jun 9, 2007 | 06:48 PM
mussashimits
Default Help- what does this code mean?
Hello,
I've been having this problem with my car for over a year. In the summer, when the weather is hot, I go to start my car, and the S light is blinking (not a certain number of times, just constant blinking). Then it doesn't want to start when I turn the key. This problem also sometimes occurs when the engine itself is hot.
What I find odd is that this occurs when the weather is hot- not when the engine is hot. I've actually already replaced my IC ignition unit recently, but the problem persists. I then tried checking the code by jumping that blue cable under the glovebox, and the blinking was as follows:
1 short
2 shorts
3 shorts
7 shorts
8 shorts
1 long
3 shorts.
Then when it starts over, the very last set of blinks is 4 instead of 3.
I still haven't found out what the code means, and that's what I'm trying to do through this post. Also, I took out the TCM unit and looked it over (I heard a faulty TCM could cause this problem) but it looks fine.
I'd really appreciate any help with this.
Thanks very much
Old Jun 9, 2007 | 08:02 PM
Default RE: Help- what does this code mean?
Please Put In your Year, Make and Model of Car and it's engine size or you more that likely wont get an answer from anyone:.
Put all that info into your signature panel in your profile...
Welcome to the Forums...
Old Jun 9, 2007 | 08:12 PM
mussashimits
I'm sorry, I forgot to do that. All I know is that it's a 91 Honda Accord.
Old Jun 9, 2007 | 08:53 PM
I would suggest resetting the ECU and TCU by pulling the BackUp fuse for 20 secs. There is no code 2 in my 90 or 94 Accordmanuals. Also w/ the service check connector shorted, any trans codes (indicated by flashing S light) are read on the S light, not the Check Engine Light.
If your codes were S-light flashes, then multiple codes related to the lock-up clutch and lock-up solenoids are present. They could be related to a bad speed sensor.
Is the Check Engine Light On also? Have you checked for any ECU codes? A bad speed sensor sets code 17. If speedometer does not work when this problem occurs, the vehicle speed sensor seems likely.
Old Jun 9, 2007 | 09:34 PM
mussashimits
Thanks for the help. The check engine light is not on. I'm not sure what ECU codes are, but I have just been checking the "S" light. It seems like recently I had replaced the speed sensor as well.
Do you happen to have a link that would tell me how to locate the backup fuse?
Thanks
Old Jun 9, 2007 | 10:45 PM
You need to download a shop manual. Check DIY section for a download of a manual.
The BackUp fuse is no. 24 fuse in 90 Accord manual and in Lower LH position.
Make sure all your transmission electrical connections are clean and secure w/ no wiring damage.
If no speedometer problems, the VSS is probably not your problem.
Old Jun 10, 2007 | 06:10 AM
BlkCurrantKord's Avatar
Take it to an autozone or similar place where they can check and read the codes for you for free. That way you get the code # and description.
Old Jun 10, 2007 | 03:37 PM
Correct me if I am wrong, but I think that Autozone only scans cars with OBDII (96 - present Accords).
Old Jun 10, 2007 | 03:48 PM
deserthonda's Avatar
All you got to do is go to our DIY section ,, obd codes, read up on your year car ,chk the codes again,,and post them here .
Old Jun 10, 2007 | 05:18 PM
ORIGINAL: PAhonda
Ah, didn't catch the 91 part.
