hey guys new here and with a problem
Old May 4, 2009 | 08:05 PM
xrtaco06
Cool hey guys new here and with a problem
hey what up guys, i have a little problem with my 93 accord.
it won't start, i have done the tune up and everything. i changed the distributor and it started, then it went out again, so i thought it was the fuel pump, changed it and still no start, then checked it with my friends distributor and it started. so i changed it for another one and bam turned on. then a week later today it left me hanging again at school. i was able to here the pump but not this time, i have warranty the distributor twice, i can do it agian no problem but it would just go out again. does anyone know whats going on here. sorry for the long thread and good to be here. thanks in advanced.
Old May 5, 2009 | 06:43 AM
So when you hear the pump it starts? And when you don't hear the pump it doesn't start? That really sounds like a bad main relay. You can search in General Tech for a bunch of threads on that.
BTW, Welcome! This is the welcome & introductions board. If this turns into much of a technical discussion I'll move it to General Tech.
Old May 5, 2009 | 12:59 PM
xrtaco06
Cool
if it was a bad relay it wouldn't start at all would it. cause when i put the new distributor on it starts up fine, its something burning the distributor but what runs the distributor. can it be the coil.
Old May 5, 2009 | 03:05 PM
I figured it might just be intermittent anyway. Distributor didn't fix it so it continued to occasionally not start. Main relay is usually an intermittent problem, worse when the interior is HOT.
So each new distributor gets fried, then it doesn't start at all? No luck just waiting & trying again like an intermittent problem?
Old May 5, 2009 | 04:44 PM
xrtaco06
Cool
nope it won't start at all only when i put a new distributor on it fires up like nothing happened at all. i got a new coil, but can it be anything else?
Old May 5, 2009 | 05:03 PM
Is your accord an EX, LX, or DX?
You really should try to figure out if the problem is due to lack of spark or lack of fuel.
If you have a timing light, hook it up to a wire. Try to start the car. The timing light should flash when hooked up to each of the 4 spark plug wires.
I am a bit confused about this part of your first post. Are you able to hear the fuel pump turn on when the car is not starting? It should kick on for about 2 seconds when you initially turn the key to the II position.
Also, there is a ground under the distributor housing that may be loose or corroded. Check that as well.
Old May 5, 2009 | 08:16 PM
xrtaco06
Cool
its a 93 lx. i was able to hear it when it worked fine and when i would put a new distributor on. when the distributor went out it wouldn't send the power to the pump so i couldn't hear it. it can't be lack of fuel because i just changed the fuel pump and it was working fine. i know it's lack of spark.
Old May 5, 2009 | 08:44 PM
The distributor doesn't send power to the fuel pump, the main relay does.
The distributor gets its power from the ignition switch.
Even a new fuel pump will not work if it isn't getting power. That is why I asked if you verified that you have a weak/no spark when the car will not start.
Old May 5, 2009 | 11:29 PM
xrtaco06
Cool
ok so i changed the coil, and the distributor again. it started up fine, maybe it can be the main relay?
Old May 5, 2009 | 11:47 PM
xrtaco06
Cool
where is the main relay located i can't find it any where?
