Hi have a misfire problem
Hi, I have a 96 Honda Accord EX with a severe misfire problem under light throttle. I have replaced cap, rotor, wires and plugs but its still there. What could be causing this problem.
Thanks |
RE: Hi have a misfire problem
maybe incorrect ignition timing??
Timing is correct. I think it is maybe in the distributor.
probably..im thinking of your ICU(ignition control module) but im not really sure..but just w8 till the others here give there thoughts..;)..
Ok lol, yeah ive never really messed with a distirbutor before im into coil packs and DSM's. It is my girlfriends parents beater and I drive it every now and then to save on gas.
Little update.
If I try and beat the crap out of the car it will make the misfire go away all together till I turn it off again. I can just turn the key off for a second and turn it back on and the misfiring will come right back. |
Coil has been problematic more frequently that ignitor in my experience. I would also check all engine compressions to make sure you have good compression on all cylinders.
good luck |
