Hi have a misfire problem
Old Aug 26, 2008 | 02:34 PM
Tsiturbomightym
Default Hi have a misfire problem
Hi, I have a 96 Honda Accord EX with a severe misfire problem under light throttle. I have replaced cap, rotor, wires and plugs but its still there. What could be causing this problem.
Thanks
Old Aug 26, 2008 | 03:24 PM
ford's Avatar
Default RE: Hi have a misfire problem
maybe incorrect ignition timing??
Old Aug 26, 2008 | 03:30 PM
Tsiturbomightym
Timing is correct. I think it is maybe in the distributor.
Old Aug 26, 2008 | 03:54 PM
ford's Avatar
probably..im thinking of your ICU(ignition control module) but im not really sure..but just w8 till the others here give there thoughts....
Old Aug 26, 2008 | 05:06 PM
Tsiturbomightym
Ok lol, yeah ive never really messed with a distirbutor before im into coil packs and DSM's. It is my girlfriends parents beater and I drive it every now and then to save on gas.
Old Aug 29, 2008 | 10:28 AM
Tsiturbomightym
Little update.
If I try and beat the crap out of the car it will make the misfire go away all together till I turn it off again. I can just turn the key off for a second and turn it back on and the misfiring will come right back.
Old Aug 29, 2008 | 11:38 AM
Coil has been problematic more frequently that ignitor in my experience. I would also check all engine compressions to make sure you have good compression on all cylinders.
kc68
Jun 16, 2016 05:17 PM
davidg99
May 5, 2011 11:59 PM
bedbaldo
Jan 5, 2007 09:41 PM
TYTALEX
Mar 19, 2006 12:57 PM
May 15, 2005 07:40 PM
