Highlights which is high beam
Old Sep 30, 2016 | 05:41 PM
eholm's Avatar
Default Highlights which is high beam
I bought a used 2007 Honda Accord but the headlights seem to be wrong and wondering if the previous owner put low beam lights in high beam sockets or vice a versa. the car takes 4 bulbs and want to make sure the low beam bulbs go in the correct position and High beam bulbs go in the high beam sockets
Question: So does anyone know which sockets are which?
Old Oct 1, 2016 | 07:44 AM
Do you have a picture? My 07 Accord isn't home right now so I can't go outside and look.....it should be home sometime today so I can go look at it later if someone else doesn't chime in before then
Old Oct 1, 2016 | 10:33 AM
Upper bulb (60w) is high beam and lower bulb (51w) low beam.
Old Oct 1, 2016 | 12:04 PM
The bulbs should have 2 wires, where one wire is black on all of them.
The other wire color for each bulb is listed below.
Driver's high - wht/yel
Driver's low - red/yel
Passenger's high - wht/grn
Passenger's low - red/grn
Either the bulbs or the connectors are switched.
Here is a video on how to change the high bulb to show the location.
hallstevenson
Aug 8, 2013 11:27 AM
stoddaj1
Nov 2, 2008 04:24 PM
stoddaj1
Nov 2, 2008 08:28 AM
angelinurdr3amz
Sep 17, 2008 12:44 AM
munishf
May 14, 2007 02:07 PM
