93 Accord High Beam Problem
Old Nov 2, 2008 | 08:24 AM
stoddaj1
Default 93 Accord High Beam Problem
We just bought this Accord and the high beam lights don't work. The bulbs have been checked and are fine. When we try to turn the high beams on, the light on the dash that would normally show they are on, is not lit. The high beam switch ( inside the engine compartment fuse box) clicks when we try to turn the high beams on. The DRL dash light is lit when the car is running though we're not sure if the two are connected. Can anyone help?
Thanks
Old Nov 2, 2008 | 01:54 PM
Default RE: 93 Accord High Beam Problem
The dimmer relay must close to enable high beams. Even though you hear it click, the contacts may be burnt preventing a good ground for high beams. The high beam indicator and high beam are grounded through the dimmer relay (under hood fuse box). Since you hear it click, the column switch is driving the relay, but relay is not closing for some reason. Other possibility is a wiring fault in high beam circuit, but that is much less likely than faulty dimmer relay.
Old Nov 2, 2008 | 04:24 PM
nafango2's Avatar
check for power at the relay with a multimeter. If you get power there, but no power at the socket for the light bulb, you can reasonable the contacts are toast.
t accord
May 19, 2014 10:45 AM
alganis
Oct 17, 2013 09:34 AM
hallstevenson
Aug 8, 2013 11:27 AM
stoddaj1
Nov 2, 2008 08:28 AM
munishf
May 14, 2007 02:07 PM
